b17a1 torque specs
Old Apr 13, 2010 | 05:12 PM
Leem21vtec's Avatar
Default b17a1 torque specs
I'm looking for the torque specs for the cam caps for b17a1 engine. Cannot find anywhere and for some reason honda/acura dealer don't have it on record. Also the rod bolt specs are 30ftlbs right?
TR "Old Skool DA" Member #80
Old Apr 13, 2010 | 08:02 PM
88_Hatchy's Avatar
I'm cooler than you
same as a B16
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Apr 13, 2010 | 08:28 PM
Kung.'s Avatar
OIL SPRAY BAR/CAM JOURNALS
-8 MM Bolts (20 lbf-ft)
-6 MM Bolts (7.2 lbf-ft)
B-Series is all the same
Old Apr 14, 2010 | 03:14 PM
Leem21vtec's Avatar
Ok what should I torque the stock rod bolts at? Is there a website or something I have been looking for a while. Thanks
Old Apr 14, 2010 | 04:23 PM
Kung.'s Avatar
Connecting Rod Bolts
Tighten connecting rod nuts in 2 stages. First tighten nuts to (15 ft. lbs.) (20 N.m), then to (32 ft. lbs.) (44 N.m).
Good luck,
Old Apr 15, 2010 | 10:19 AM
89crxsir's Avatar
I have the factory manual on .pdf...
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
