Need help with timing belt 96 integra
Old Mar 28, 2010 | 12:13 PM
dcintegra96's Avatar
Post Need help with timing belt 96 integra
I bought a new timing belt for my 96 dc integra 5 speed... put the belt and adjusted the time, but the belt runs a lil bit off the cam gears...any ideas??
Old Mar 28, 2010 | 12:16 PM
Secondz's Avatar
Built Not Bought
the timing belt tensioner?
Old Mar 28, 2010 | 12:24 PM
i did also tightened the timing belt tensioner...is there a specific way to it?
Old Mar 28, 2010 | 01:13 PM
integra's Avatar
90% grind 10% sleep
put allen keys in the cams to hold them lined up. then redo.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Mar 28, 2010 | 01:15 PM
so hold cams in time and put belt? i also forgot to mention , that recently i changed the head gasket and the head was taken to the machined shop to be shaved, does this make a difference? would i need a NEW timing belt tensioner??
Old Mar 28, 2010 | 04:00 PM
Secondz's Avatar
Built Not Bought
Quote from the manual for tensioning the belt (1998 Integra page 6-9)
1) Remove the cylinder head cover.
2) Set the No. 1 piston at TDC
3) Rotate the crankshaft five to six revolutions to set the belt.
4) Set the No. 1 piston at TDC
5) Loosen the adjusting bolt 1/2 turn (180deg) only.
6) Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley.
7) Tighten the adjusting bolt to the specified torque.
After adjusting, retorque the crankshaft pulley bolt to 177Nm.
Old Mar 28, 2010 | 04:16 PM
CRXkid24's Avatar
uh oh
Sounds like u didn't put the timing belt guides back on
my car gets mad after 5,500 rpm!
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old Mar 29, 2010 | 05:33 AM
ok...might have miss the guides..wheres is that at?
Old Mar 29, 2010 | 06:13 AM
CRXkid24's Avatar
uh oh
On the crank there's a timing belt gear there should be one on each side of that gear
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old Mar 29, 2010 | 05:52 PM
mogo21's Avatar
+ 1 on the guides check that asap , or serious problems will occur
