Need help with timing belt 96 integra
Old Mar 30, 2010 | 08:18 AM
Good advice on the procedure and the guides......
Thanks for helping him out CRXkid and secondz.
Rep for you.-Bob
Old Apr 1, 2010 | 01:47 PM
dcintegra96's Avatar
if is the 2 small metal pins..they are already in place i just chek to make sure..
Old Apr 2, 2010 | 05:07 AM
dippincrx's Avatar
save the s.o.h.c
they are not pins. they are more like washers i guess. they go on the crank shaft. you would put one on with the bevel going outwards then put the gear on timing belt and the second bevel outwards. if you do not put these on the belt will walk off the camgears.
