Checking CEL.....
Old Mar 16, 2010 | 09:33 AM
Gotin's Avatar
Sayien
Originally Posted by sprjit22
You need to start by pulling the code. Go to phearable.net and he has all the pin outs so you can find the one for the check engine light. It is foolish to start replacing parts when you haven't pulled the code. Since the car clears the code when you shut it off then don't turn it off.
These two sound like it, but not sure,
A13: Malfunction Indicator
D4: Service Check Signal (placing my bet on this one)
Do I just ground this wire to get the code to flash?
-B.J.F-
Old Mar 16, 2010 | 12:18 PM
integra's Avatar
90% grind 10% sleep
A13 and yes ground
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Mar 17, 2010 | 05:41 PM
eightwun3zfynest's Avatar
sleeper
all u gotta do is check one of these threads
[FAQ] ECU Codes for everyone - Honda-Tech
The new cel thread (how-to & codes) - Honda-Tech
Old Mar 18, 2010 | 05:00 AM
Gotin's Avatar
Sayien
Originally Posted by eightwun3zfynest
Its not that simple. Ive tried to used the jumper, but it does not work. Not sure if it has something to do with obd0-obd1 conversion, or just shity wiring job.
Have not been able to make it out to storage to try the recommended methods.
-B.J.F-
Old Mar 18, 2010 | 08:42 AM
sleeper
oo ok. ill try and connect the jumper to my h22civ real quick and see if it works if not ill find out what you gotta do cuz the car is swapped so maybe it wont work idk ive never had to check the cel myself on my civ soo idk let me do some research for ya
Old Mar 18, 2010 | 08:50 AM
sleeper
haha your right it dont work. i got a 02 sensor code but when i connected the jumper it did nothing.
Old Mar 18, 2010 | 09:07 AM
  #17 (permalink)
Gotin's Avatar
Sayien
Well thats good to know. I was starting to worry that I found something else wrong. Thanks..
-B.J.F-
Old Apr 4, 2010 | 10:07 AM
  #18 (permalink)
Gotin's Avatar
Sayien
First post.
-B.J.F-
Old Apr 6, 2010 | 01:59 PM
  #19 (permalink)
Gotin's Avatar
Sayien
It did not work b/c it's not A13 that needs to be grounded. It was what my gut told me a first D4. Got the code today. (Thank you Ryan from Rywire)!
-B.J.F-
Old Apr 9, 2010 | 07:57 AM
  #20 (permalink)
sleeper
ok so connecting d4 works then good. but i got a dumb (noob) question. by grounding d4 what do u mean?? take it out of connector and ground it?????
