Starting Problem with Fuel pump/Main Relay
Old Mar 12, 2010 | 06:46 PM
Chris_2jz's Avatar
Exclamation Starting Problem with Fuel pump/Main Relay
I have a 93 Honda Civic EX and i was having starting problems because of the Fuel Pump Relay/ Main Relay (Fuel pump not primeing), So i bought a used one and it was working fine up untill yesterday and now it does it every single time i try to turn on the car (fuel pump not primeing) so i called my mechanic and he told me to buy a new fuel pump and relay so i did and i installed it myself. Now i have a new problem. The new fuel pump didnt work either (wouldnt prime) so i took it out and put my old one back in. and now my car wont start after putting everything back together.... so if something can throw any recommendations to me please feel free.... I really need help, need my car to work so i can make it to work.... PLEASE HELP!
Thanks in advance.
Old Mar 12, 2010 | 06:48 PM
YARO's Avatar
Smith & Wesson Protected.
Whne you turn your ignition to "on" does the main relay click and CEL turns off?
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Mar 12, 2010 | 06:54 PM
Chris_2jz's Avatar
No the Relay doesnt click. Idk why because i bought it brand new from honda for 80 bucks and no the check engine light does not go away
Old Mar 12, 2010 | 06:57 PM
Chris_2jz's Avatar
The only way i can get the fuel pump to prime is by putting a constant 12v from the battery and put it on the Yellow/Green from the fuel pump and it primes problem is it wont start.
Old Mar 12, 2010 | 07:01 PM
racers4life77's Avatar
P.O.S S14
Does it at least turn over?
Fender roller for rent w/ heat gun $35. If you want to take it home, you have to put up the full price of the tool as a deposit $300, and $25 a day.Deposit refundable upon inspection of the tool. If you damage or lose it you buy it. Located in Tampa.
Old Mar 12, 2010 | 07:13 PM
Chris_2jz's Avatar
if you mean it wants to turn but doesnt and it keep whining then yes the crankshaft turns but the car will not start up
Old Mar 12, 2010 | 08:34 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
if you've straight wired the pump and it's still not working then the pump is bad.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Mar 13, 2010 | 05:31 AM
Chris_2jz's Avatar
Well I put a new fuel pump yesterday and tired straight wiring the new one and it wouldn't prime, so wat I did was put the old back in and straight wired that one and it primed but didn't start.
Old Mar 13, 2010 | 07:07 AM
HonkeyDong's Avatar
Every dog has his day.
check your grounds
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Mar 13, 2010 | 09:32 AM
Chris_2jz's Avatar
Any spots in specfic? Or wires? I have a test light that you plug in into the a/c adapter and it tests you wats positive or wats negative. The yellow/green wire coming outta the fuel pump is grounded and the same wire entering the Main relay is'nt reading at all....
