Starting Problem with Fuel pump/Main Relay
Old Mar 13, 2010 | 09:37 AM
Chris_2jz's Avatar
When I check the main relay I noticed thar terminal 1 (I'm assuming the wire leading to ecu?) Has power everything thing else is grounded.... idk if that's normal or not?
