When give gas, rpms drop...
Old Mar 11, 2010 | 05:45 PM
Thatguysstuff's Avatar
Hey its that guy!!
maybe timed 180 off??
seen this done many times...
Old Mar 11, 2010 | 05:53 PM
YARO's Avatar
Smith & Wesson Protected.
damn man this is like problem number 1000? do your self a favor and burn that car. Unless is a eg hatch sell me the shell then throw the motor in a lake lol.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Mar 11, 2010 | 07:01 PM
Secondz's Avatar
Built Not Bought
try and reset your timing, you my think its good but make sure your top dead center lines up... and then take your dizzy apart... just look for stuff, tighten some bolts and screws and retard it ALL THE WAY! thats what i had to do... mine was doing the SAME thing, like i said in your old thread... i reset my timing and retarded my dizzy and now it runs perfect!
Old Mar 11, 2010 | 07:25 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
it's impossible too do on Honda's, the dizzy only goes on one way.
plus if a motor was 180 off it wouldn't run.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Mar 11, 2010 | 08:16 PM
YARO's Avatar
Its difficult but not impossible. Seen this happen before. The car obviously won't run.
Old Mar 11, 2010 | 08:21 PM
Hey its that guy!!
Hmm.. I have seen it.. Strange I know..
i would deff try the next way to top dead it by pulling out the spark plug in #1 and stick a long screwdriver or the oil dip stick in the spark plug hole into the motor.. then turn it slowly with a wrench on the crank bolt till it hits top dead.. you will see it go up and level out. then check the mark on the crank pully..
Old Mar 11, 2010 | 10:27 PM
  #17 (permalink)
lopezchris21's Avatar
thats exactly how i do it. ... i mean car ran perfect before guyz then started out of no where to mis, then stopped then started even more and now its all the time..... i did nothing different.
TR 5th Gen Civic CREW Member # 04
Old Mar 12, 2010 | 09:56 AM
  #18 (permalink)
Old Mar 12, 2010 | 09:58 AM
  #19 (permalink)
CRAWFORD BUILT
run some injector cleaner through the fuel system
CRAWFORD BUILT
DC Crew Member #23
Old Mar 12, 2010 | 10:03 AM
  #20 (permalink)
i did.
