Let's discuss breather setups...
Old Mar 11, 2010 | 04:48 AM
  #61 (permalink)
KJ's Avatar
KJ
bored at work
Originally Posted by custom240sx
No the nipples and such that I used were 5/8th. Thanks for the input. Also, when would you suggest I upgrade that (HP figure)? Would it be sufficient to 300whp? Also, can YOU weld aluminum?
The only way to know for sure is to tap into the crankcase at one of the fittings and put a boost/vacuum gauge or map sensor on it and log pressure. If the pressure stays neutral then you have a decent crankcase venting system. If you build a pound or two of positive pressure then you need to upgade. That is not really the most practical unless you have some type of good standalone so it is just easier to overdo the breather system from the start IMO.
My little rule of thumb as far as breather setups go:
200 or less you are fine with stock pcv system.
200-350whp run a single can off the back of block (Endyn style)
350-500 run a singe can off the valve cover and tie into back of block for drain back
500+ large volume can off valve cover like X and Flaco's setup.
Yes I can weld aluminum and own a tig welder.
BTW X the setup looks good. You really cleaned up that engine bay compared to last time, lol.
Old Mar 11, 2010 | 04:57 AM
  #62 (permalink)
Alpha's Avatar
That's an old picture. It's cleaner than that now
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Mar 11, 2010 | 06:00 AM
  #63 (permalink)
KJ's Avatar
KJ
bored at work
I need to meet up with you guys next time everyone heads to the track and check it out. Been out of the loop for a while.
Old Mar 11, 2010 | 06:09 AM
  #64 (permalink)
Alpha's Avatar
He's finishing his new fuel system. I'm leaving for Texas the 18th and I will be back the 22nd. So if he finishes his new fuel system and we dyno or track it before than I will give you a call. Need to get you back out with that EVO
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Mar 11, 2010 | 08:01 AM
  #65 (permalink)
JoKiE crx4294's Avatar
popeye built!
Originally Posted by poorboy44
have you ever had this problem? do you have any "proof" of this being an issue?
If I remember correctly, X was making 500+whp with a sigle moroso can to the back of the block setup for a drainback and never had issue... Im sure X and alpha can throw in more details on that....
No, I have a baffled custom 2 quart can and im not running alot of boost...Iv just read that its common to push alot of oil out of the gallies under high boost going down the track..Not necessarily on the dyno will it do it.
Can't spell strength without tren
AAS...It's whats for dinner
Old Mar 11, 2010 | 08:03 AM
  #66 (permalink)
popeye built!
dont Ls/vtec motors have higher crankcase pressure than other vtec motors?
Old Mar 11, 2010 | 08:50 AM
  #67 (permalink)
KJ's Avatar
KJ
bored at work
Nope, just that the 96+ ls blocks and all crv blocks do not have the provisions on the back of the block for the oem breather/pcv system. They just ran a pcv valve on the valve cover but once you threw a vtec head on it it had no pcv system and you had to install a breather like the Endyn setup.
Old Mar 11, 2010 | 09:17 AM
  #68 (permalink)
TheRedDragon's Avatar
Thanks KJ. 240 those are just regular line fasteners from amazon. Alpha you better be ready after Texas ur ass will have some power to make.
ALPHA TUNED
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
inductionperformance.com
Old Mar 11, 2010 | 09:41 AM
  #69 (permalink)
InsaneCivicCoupe's Avatar
Retired Ricer...
Those clamps X has on the valve cover are pretty common... I actually have them in the exact location on my car... Just go to your closest Home Depot or Lowes down the aisle where they have wiring, connectors, conduit etc. They are just called cushion clamps... Come in tons of sizes too... I have a shit ton of them layin around in different sizes... If you just need a couple I will give them to you...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Mar 11, 2010 | 10:58 AM
  #70 (permalink)
custom240sx's Avatar
DC Crew Member #1
Yea I need them but it's cheaper for me to grab them from homedepot as I live over a hour north of tampa.
