putting pistons into my h22
Old May 28, 2002 | 03:43 PM
d98clturbo's Avatar
what do i have to do to put forged pistons in my h22...
do i need to sleeve the block or can the piston go into the stock block?
if you can't beat me join me...& if you can beat me...DAMN!!!!!!!
Old May 28, 2002 | 05:55 PM
Bill's Avatar
Livin' in Seattle
cylinder hone possibly a slight bore if cylinders are deeply scarred sleeving not necessary.
Old May 28, 2002 | 06:10 PM
88EFSiR1J1's Avatar
the block does need to be resleeved with iron sleeves or your youll get scaring on the cylinder walls the H engines dont use iron sleeves like the Bs
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
Old May 28, 2002 | 06:35 PM
b16aRacer's Avatar
Moon Equipped
H22 = closed deck use youre money elsewhere.
'00 FBP Si
Sebring rule in effect
Old May 29, 2002 | 08:02 AM
therainforest's Avatar
b16a racer = pwn3d you all
Old May 29, 2002 | 04:53 PM
marksaccord95's Avatar
TR Registered Member #5
you must sleeve an h22a to run aftermarket pistions due to the lining on the cylinder walls.
http://www.floridaracing.org
Old May 29, 2002 | 06:11 PM
Bill's Avatar
Livin' in Seattle
(Cut/Paste from other thread)
...Ive heard the same thing and theres no definative answer.
It would be interesting to see some cold hard facts on the matter if anyone has experience on it. My thoughts would be since the 97+ blocks have a semi-exotic liner and are supposedly very susceptible to piston expansion/contraction the simple path would be to source a quality forged piston with a high silicon content.
