what head stud kit???? help plz
Old Feb 8, 2010 | 10:52 AM
sullivanracing06's Avatar
Default what head stud kit???? help plz
hey tr if im putting a gsr head on a ls block i should order the arp head studs for a gsr correct?
i just got them in and 5 are to long??? am i crazy??
can xsome one please throw in there two cents.............
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Feb 8, 2010 | 10:58 AM
rangcrx's Avatar
engine building &best
you can use either b16 or gsr..if 5 are long then you need to have your threads check on that block cause something is not letting them go down maybe they are stripped
i love AUTOZONE
Old Feb 8, 2010 | 11:07 AM
custom240sx's Avatar
DC Crew Member #1
I thought b16 wouldn't work for lsvtec's
Old Feb 8, 2010 | 11:19 AM
rangcrx's Avatar
yeah they work they are about 2mm shorter but will work if ya got them other wise you can just buy the gsr
i love AUTOZONE
Old Feb 9, 2010 | 04:51 AM
ok i got the gsr's to work perfectly!
and no b16 studs wount work with a gsr head n vice versa
hope my mistake helps someone in the futrue
Sullivan Racing LLC
352-665-2496-Tom
Old Feb 9, 2010 | 05:11 AM
rangcrx's Avatar
^thats odd i have a gsr block with a b16 head sitting right next to me with b16 studs fully assembled
i love AUTOZONE
Old Feb 9, 2010 | 03:39 PM
DC Crew Member #1
He has a b18b1 bottom end (or a1 doesn't matter)...not a gsr bottom end.
Old Feb 9, 2010 | 08:30 PM
and im using a gsr head (thats why im using gsr studs) if i had a 16 head id be using 16 studs
Sullivan Racing LLC
352-665-2496-Tom
Old Feb 9, 2010 | 08:55 PM
DC Crew Member #1
No you'd still be using gsr studs because they are the correct length for an Lsvtec/crvtec application.
Old Feb 9, 2010 | 10:00 PM
yes and like i said, a b18a block with a gsr head, allowed me to run the arp gsr headstuds, there not a specific ls/vtec or crvtec set
Sullivan Racing LLC
352-665-2496-Tom
