what head stud kit???? help plz
i guess were both on the same page
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
same thing,i wasjust saying cause he said you cant use gsr studs on a b16 or b16 on a gsr, lsvtec the same your only going by head the block setups the same..now they even mark some studs as a lsvtec stud kit and thats just the same as a gsr kit just for people that are confused and to make it easier to buy but yes, b16 studs will work on a lsvtec setup with a b16 or gsr head..but the gsr r the right ones
i love AUTOZONE
i love AUTOZONE
k, thanks for clearing tht up, will make it easier in the future for me or someone doing this head sway in the future...
Sullivan Racing LLC
352-665-2496-Tom
Sullivan Racing LLC
352-665-2496-Tom
^no problem that's what tech is here for,that's how I kindda knew what was wrong with your studs most people take the head right off and oil and coolent fall to the holes and when people try puttinf bolts or studs it will not go down all the way..so when people bring mea block to build 1st thing I do is check the walls then 2nd is the bolt holes for that problem or stripped threads..good luck with your build
i love AUTOZONE
i love AUTOZONE
the block had been sitting from a old car for months, knew the holes were fine. just needed to change the studs
Sullivan Racing LLC
352-665-2496-Tom
Sullivan Racing LLC
352-665-2496-Tom
