B16 timing belt.....
Old May 19, 2002 | 06:09 PM
EFreeland's Avatar
Make sure you follow the procedure in the FSM for the adjusting the timing belt tensioner. WIth the tensioner bolt loosened turn the crank pulley counter clock wise until the cam sprockets have rotated three teeth. Then tighten the tensioner bolt and you are done. THere should be tension between the exhaust cam sprocket and crank pulley.
HTH.
*****IMO*****
