obd0 pcv ?
Old Jan 27, 2010 | 03:31 PM
SHADYTEG's Avatar
Default obd0 pcv ?
ok befor I got this car the guy befor had took out the pcv and took the two hose coming from that box on the back of the block and ran them to a gator aid bottle .then he had the hose that ran from the intake pluged it. at the valve cover was a hose with a plug in it .I put a filter on it but now the thing blows like a quart of oil into the bottle every 25 laps.one more thang when we changed oil put 4 quarts in and was a quart low .found out the dipstick is shorter than my 93 integra by the way this is a 90 integra. would think it needs a rebuild but with all the jacking around with the crankcase presure system .could it be something with that .
Old Jan 27, 2010 | 03:36 PM
custom240sx's Avatar
DC Crew Member #1
First off, a 90 and 93 integra have the same length dipstick. Get the correct one for the motor.
Second, the pcv system should be connect like this...
Hose from middle of intake runs down to the valve which will sit in the circular metal bracket between runners 3 and 4 on the intake manifold right next to the head. This hose attaches to the top of the pcv valve. Underneath the PCV valve, a hose runs from there to the box...looking straight down at the box, the hose goes to the right hole.
As for the valve cover, you can run just a little breather filter deal on that and be fine. With the amount of blow-by you are having I would NOT connect it to the intake arm like the factory setup is done as you will be blowing oil back into the intake manifold causing higher intake temperatures and more chance for detonation and sparkplug fouling.
Buy a helms/haynes manual...why do I have to say this in about every other post I make on here...
Old Jan 27, 2010 | 03:49 PM
SHADYTEG's Avatar
so the only thing that could cause that much blowby would be rings ?
Old Jan 27, 2010 | 04:16 PM
DC Crew Member #1
Yes and no...could be caused by the pcv valve system being jacked with. Set it back to the way a helms or haynes manual shows.
Old Jan 27, 2010 | 04:25 PM
SHADYTEG's Avatar
thanks . will do that when I get home tomorrow
Old Jan 27, 2010 | 04:37 PM
DC Crew Member #1
Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland
There is your schematics
Old Jan 28, 2010 | 02:24 AM
rangcrx's Avatar
engine building &best
^his right YOU MUST first find a pcv box get rid of your setup your going to kill your oil rings with that pressure building up there!!!!! BUY A PCV BOX AND HOOK IT UP RIGHT!!!
i love AUTOZONE
Old Jan 29, 2010 | 07:46 PM
SHADYTEG's Avatar
the box is there but both hoses run to that stupid gateraid bottle.should I change the box and get a new one ?got a PCV valve today.will look tomorrow at my 93 to see were hose to top left of box goes .cant find that info in the HAYNES and can not tell from this schematic were it goes.
Old Jan 30, 2010 | 04:02 AM
rangcrx's Avatar
By null at 2010-01-30
i love AUTOZONE
Old Jan 30, 2010 | 04:17 AM
DC Crew Member #1
Thanks rang...I didn't feel like making it THAT obvious...didn't think the original was hard to read.
