Difficulties Starting My Hatch?
Old Feb 4, 2010 | 04:40 AM
integra's Avatar
90% grind 10% sleep
look at teh light on the ecu it flashes the check codes....long flashes 10 and short flashes 1
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Feb 5, 2010 | 12:50 AM
JDMRican's Avatar
Ok. So on the ecu I'll see the lights flashing?
92' EG Ferio [D16z6] Stolen, & Sold.
89' EF Sedan [D15b7] Sold.
92' CB7 Accord [F22A1] Sold.
89' EF Hatch [JDM DOHC ZC] Sold.
90' EF Sedan [D15/Y8 VTEC] TRADED.
94' EJ2 Coupe [B16/GSR Tranny] DD.
Old Feb 5, 2010 | 06:07 AM
KushedRacer's Avatar
there is one light/buld on the top of your ecu. like integra said
long flashes=10
short blips=1
add them all together and you have a number that coorelates to a code you can lookup online.
Old Feb 15, 2010 | 01:15 PM
JDMRican's Avatar
Well I Was Messing with the distributor and it picks up idle goes up to 1, 000
but then it drops suddenly again? and i dont know how to read the ecu codes. lol sorry.
Old Feb 16, 2010 | 09:08 AM
up to 1, 000 but then it drops suddenly again? and i dont know how to read the ecu codes. lol sorry.
Originally Posted by senor honda
A-parts stores check those lights for free......have a printout as to what it needs.-Bob
Old Feb 16, 2010 | 11:37 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
either timing needs to be dialed in or the IACV is bad. you can just unplug it and turn the idle screw up for now but it will through a CEL. and your firing order is right, if it wasn't it wouldn't fire over at all. you could have one plug not firing though and it's only running on 3 cylinders.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Feb 16, 2010 | 11:43 AM
  #17 (permalink)
FrodoGT's Avatar
Found the Vtec switch.
Check both your mechanical and ignition timing. Then look at your map sensor.
TR Old Skool EF Crew #24
Old Feb 18, 2010 | 09:46 PM
  #18 (permalink)
JDMRican's Avatar
Yeah Good Looks, its one of those sensors that was plugged up wrong.
some of them arent plugged up still and the car sounds pretty good righ tnow.
i just dont have no second gear lol
