CEL OBD-0 B16a CRX
Old Jan 18, 2010 | 04:06 AM
vt_sol_ec's Avatar
I Give My .02 When Needed
Originally Posted by Tampa's_Slow_EG6
good luck man!..
Thanks bro!
Got the TPS last night, gonna try to get a gasket for it today and hopefully no more CEL!
Nikon Owner
IG: @equippedphotography
FB: Equipped Photography
1994 Integra RS - Stock LS/SOLD
1994 Del Sol - Stock D16y8/TRADED
1990 CRX Si - SiR B16a/TRADED
1998 Integra GS - JDM B20b/TRADED
1994 Integra GSR - Tuned H22a/TRADED
1999 EK Coupe - Backburner
1995 JDM Front Integra - Project
2014 F-150 5.0L - DD
Old Jan 18, 2010 | 10:18 AM
nocomply540's Avatar
is retired...
Originally Posted by vt_sol_ec
Thanks bro!
Several people have told you to check the voltage on the TPS before you go putting another one on there. IIRC put a multimeter on the hot wire to the TPS then ground it out turn the key to the on pos. and check the voltage both at open and then at WOT. If it's out of specs then adjust it.
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Jan 18, 2010 | 10:43 AM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
now my question is... how would he adjust it? i think im having the same problem in my single slam..
and wouldnt putting another one, solve the problem anyway? i mean the new one should be calibrated right?
Old Jan 18, 2010 | 10:49 AM
custom240sx's Avatar
DC Crew Member #1
No it wont be calibrated. You have to cut a slit into the screws that are on the tps now...unscrew them just a bit (enough to spin the tps)...you then adjust it from there.
Old Jan 18, 2010 | 10:56 AM
interesting... thnx for the answer...
Old Jan 18, 2010 | 10:57 AM
DC Crew Member #1
It may however still be his TPS if it doesn't read a steady voltage. This is why we said calibrate it first before installing the new one. I did a quick google search and didn't find any pictures but there were a ton of write ups so just search it.
Old Jan 18, 2010 | 11:03 AM
  #17 (permalink)
vt_sol_ec's Avatar
I never even knew that you could calibrate a TPS. How will I know when I have the specs right?
Nikon Owner
Old Jan 18, 2010 | 11:05 AM
  #18 (permalink)
DC Crew Member #1
Your better off getting someone on here to do it for you and you just throw them like $20. I'm certain a lot of people will have no issues helping you out for a 18 pack of beer ...I would if you lived in my area.
Old Jan 18, 2010 | 11:14 AM
  #19 (permalink)
vt_sol_ec's Avatar
Ha I've just never messed with a TPS sensor on any car and don't really know what I'm supposed to do. I've got some friends near here that can help me out.
Nikon Owner
Old Jan 18, 2010 | 11:36 AM
  #20 (permalink)
DC Crew Member #1
Just buy a helms manual...it will explain how to in detail...plus you can use it in the future.
