need someone with honda knowledge, please help
Old Dec 22, 2009 | 12:42 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
is there a clicking sound? could just be a weak battery. lights would still come on but it won't have the juice to push the starter.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Dec 22, 2009 | 12:43 PM
CRAWFORD BUILT
the starter is on top of the tranny right under the dizzy. it's held on with two 14mm nuts and it's not hard to get out.
CRAWFORD BUILT
DC Crew Member #23
Old Dec 22, 2009 | 12:44 PM
custom240sx's Avatar
DC Crew Member #1
^ only problem is they can test good but the solenoid can be crapping out anyway. This happens a lot on b-series.
Old Dec 22, 2009 | 12:47 PM
SPJosh's Avatar
no clicking sound and yea i saw where it was
"I wasn't looking at your car. I was looking at you to make sure you were looking at mine"
1998 Isuzu Hombre - Sold
1996 Volkswagon Jetta GL - Wrecked - Fixed - Sold
2008 Scooter - Sold
1994 Chevrolet Camaro - Sold
1996 Volkswagon Jetta GL - Traded
1994 Volkswagon Golf GL - FOR SALE: https://www.tamparacing.com/forums/c...4-vw-golf.html
Old Dec 22, 2009 | 12:49 PM
CRAWFORD BUILT
yeah that's why i wanted him to straight wire it, too bypass the solenoid.
CRAWFORD BUILT
DC Crew Member #23
Old Dec 22, 2009 | 12:50 PM
CRAWFORD BUILT
i'd pull the starter and battery and get them both tested. if they both check fine then it's either a wire or the solenoid.
CRAWFORD BUILT
DC Crew Member #23
Old Dec 22, 2009 | 12:54 PM
  #17 (permalink)
TheRichMan's Avatar
isn't actually rich...
So... It doesn't click or anything? Yet when you move the transmission into reverse and put it back it starts sometimes? My girlfriends Automatic accord won't let you take the keys out sometimes because it doesn't realize it's in park. The shifter needs to be jiggled a little bit backwards. Maybe that has something to do with it? Because if it can start some of the time then the starter Itself Is probably not the issue.
Old Dec 22, 2009 | 12:55 PM
  #18 (permalink)
CRAWFORD BUILT
^+1 did you try starting it in neutral?
CRAWFORD BUILT
DC Crew Member #23
Old Dec 22, 2009 | 12:57 PM
  #19 (permalink)
DC Crew Member #1
Yes...the park/neutral sensor is probably worn out.
Old Dec 22, 2009 | 01:09 PM
  #20 (permalink)
TheRichMan's Avatar
^thats my guess.
