is a stock b20 block with built gsr head good setup
is a stock b20 block with built gsr head good setup the gsr head has crower valve train 3 angle valve job and skunk2 stage 2 pro cams and cam gears can any give me any info
If the block was built good with higher compression/ balanced/girdle Then yes. Stock not so much
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
Your compression is going to be at or around 9:1. That with Skunk2 Pro 2 cams will be a bad all motor setup. It will not make power and the only way it will make a little power is to dial in the cams and a real good tune. I would recommend some higher compression pistons (12:1+) and a good header (DTR or HyTech). That or throw a nice ramhorn and Precision 6262 ontop
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
B20 84.50 bore
14.3:1 compression
Skunk2 68mm throttle body
Skunk2 Pro 2's
Flat faced .5mm oversize valves
SMSP header
Pure Tuning ported polished head
Edelbrock Victor X intake manifold
This is just an example of what compression and a good setup can yield
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
