ACL race bearings Questions.
I was wondering if anyone that has used these bearings knew how long they last compared the the ACL Std bearing set or even OEM bearings. I heard the ACL Race bearings have a shorter life span and seeing how i wanted to build a Long lasting and reliable B20/Vtec revving to 8k, i dont want to have to put new bearings in it 40-60,000 miles down the road. This is just a general question about the ACL Race bearings, not how to build a motor to last for XXX,XXX amount of miles and how my motor is being Driven, Built, and what parts are installed.
Thanks for all the help.
EM1 Crew Member #3 !!!
2000 FBP Si
2000 FBP Si
it depends on how you clearance the motor.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
They give more clearance / looser and have a coating. That's all. Same material
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
What did the clearances work out to?
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
i don't remember, everything was written down and i lost the paper work. the crank had a smaller diameter on cylinder 3 and 4 and i thought that i'd still have enough for the bearings too work, but it didn't lol. 4 was fine, but 3 was knocking bad. standard size on the crank is 1.771" if i remember correctly.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
acl race bearings are the best bearings you can buy..they take alot to make them work perfect they will outlast stock bearings...but you must have a SPOTLESS crack to use them and i would not use them on stock rods only hbeams"but thats just me"you CAN NOT TOUCH THE BEARING WITH YOUR FINGERS AT ALL!!!!!and your crank must be polished and within spec...but as for them lasting your info was wrong they will last..
i love AUTOZONE
i love AUTOZONE
apparently it was and i wasn't told. i've heard good things about them too, i've just had bad personal experience with them. same thing with the XTD clutch i had, heard alot of good things about it but it doesn't last 300 miles. i've never bought OEM bearings for a build simply because i believe aftermarket to be better for a "built" motor. i'm using Calico's now so i'll see how they go.
CRAWFORD BUILT
DC Crew Member #23
