Which spark plug heat range should I run?
Old Dec 14, 2009 | 04:17 PM
FoxHondaRider's Avatar
Registered Hater
Default Which spark plug heat range should I run?
JDM ITR, I have 2 sets of NGK-R Iridium plugs. One set is 6 and the other is 7. 6 is what was called for by the factory but would I see any benefit running the colder plug (7)?
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Dec 14, 2009 | 06:35 PM
Some people would go by the color of the insulator as to it
being too hot or too cold.-Bob
Old Dec 15, 2009 | 10:23 AM
Registered Hater
Those test used to work good before additives in gas were put into place, still works to an extent. I can read plugs so maybe I should throw the 7's in there and see what they look like after some runs. When I pulled them out before the motor was even started they looked rich.
Old Dec 20, 2009 | 05:40 AM
lzylst's Avatar
They original plug was probably a 7 huh. Due to little higher compression and more aggressive fuel/timing maps than a usdm motor.
The 7 will use more fuel, run cooler, and help if you have any detonation.
Vance @ 863-604-2139 for any questions
Old Dec 20, 2009 | 06:09 AM
integra's Avatar
90% grind 10% sleep
Burning cooler will not burn all the gas in the combustion chamber.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Dec 20, 2009 | 07:42 AM
custom240sx's Avatar
DC Crew Member #1
Run stock plugs unless you have bumped compression or introduced nitrous or forced induction.
Old Dec 20, 2009 | 01:09 PM
Registered Hater
never thought of that lol I cant remember if the specs I was looking at was for JDM or USDM. Whoever owned it in Japan put in NGK Iridium R 7 heat range.
Old Dec 20, 2009 | 01:56 PM
Alpha's Avatar
BKR6E or BKR6EIX. Prefer the BKR6EIX but more expensive
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 20, 2009 | 01:57 PM
DC Crew Member #1
^ That's what I thought...
Old Dec 20, 2009 | 03:42 PM
Registered Hater
I just looked at the box I'm running BKR6EIX. I dont even remember how much I paid but with how damn expensive my motor is, $40 or so for plugs is nothing lol I wasnt about to take any shortcuts, I want the best in there. Well now I know I'm good with the plugs I put in. And I have an extra set of plugs for different mods later down the road.
