moates burn2 problems ! CROME 1.5.3
Old Dec 9, 2009 | 05:37 PM
teamjdm239's Avatar
6speed rhd integra!
Default moates burn2 problems ! CROME 1.5.3
i go to settings, have it on com port 4 , baud rate 920000, and i test connection. "successfully connected to ecu"
but when i go to burn the bin. it says no connection detected. :/
then, i close crome, i re-open it, and reopen my bin file.
i hit write , and it says "the operation failed after 3 attempt(s) with 250 milliseconds between each attempt.
K*Squad
Uk spec 99 rhd dc2 integra
MugenPower
Old Dec 9, 2009 | 07:01 PM
dippincrx's Avatar
save the s.o.h.c
use the moates flash and burn software. pick what chip you are using. if the chip has been used make sure you erase it as well. then load your bin to buffer and write chip.
Old Dec 9, 2009 | 11:13 PM
94mightymax's Avatar
does ur computer have vista?
if so you have to right click crome and select run as administrator.
Old Dec 10, 2009 | 10:13 AM
teamjdm239's Avatar
6speed rhd integra!
its windows 7, would this still apply? crome works good for the ostrich 2, just not for the burn2 for some reason.
K*Squad
MugenPower
Old Dec 10, 2009 | 01:38 PM
dippincrx's Avatar
save the s.o.h.c
just use the software for the burner
Old Dec 11, 2009 | 04:28 AM
teamjdm239's Avatar
6speed rhd integra!
its not available on their site, it says its corrupted when i try and open it.
K*Squad
MugenPower
Old Dec 11, 2009 | 05:00 AM
dippincrx's Avatar
save the s.o.h.c
Flash & Burn Program for BURN1 [FLASHBURNPRO] - : Moates.Net
Old Dec 11, 2009 | 04:00 PM
teamjdm239's Avatar
6speed rhd integra!
thanks for the link, but i already downloaded this from their site. it says the file is corrupted when i try and open it.
K*Squad
MugenPower
Old Dec 12, 2009 | 02:53 AM
dippincrx's Avatar
save the s.o.h.c
i have the disc if you know how i can put it online let me know
Old Dec 12, 2009 | 05:25 AM
Jun_Tuning's Avatar
VTEChnician
yup
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
