moates burn2 problems ! CROME 1.5.3
Old Dec 12, 2009 | 05:27 AM
Jun_Tuning's Avatar
VTEChnician
Originally Posted by dippincrx
just use the software for the burner
it don't work in windows 7
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Old Dec 12, 2009 | 05:38 AM
dippincrx's Avatar
save the s.o.h.c
Burning Chips with CROME
To configure the Moates Burn1, we use the exact same procedure as we did for Configuring the Ostrich:
1. Open the Device Manager
2. Connect the Burn1 (Disconnecting the Ostrich if necessary)
3. Note which COM port the device was assigned
4. Launch CROME
5. Goto File->Settings-> Real Time Programming
6. Set the COM Port to the port you noted in step 3.
Note: Since the traditional Atmel 29C256 chips have been long since discontinued, the Burn1 and CROME both fully support the replacement SST 27SF512 chips. In order to use this type of chip, make sure you Check “Used for 27SF512” under the Settings->Real Time Programming
7. Click Test Connection
If this Test Fails, refer to the Troubleshooting section of this document.
8. Click OK
9. Click
10. When you click Put, the open ROM will be burned to the chip in the burner.
15
Old Dec 12, 2009 | 08:56 AM
teamjdm239's Avatar
6speed rhd integra!
cool, got it . thanks.
K*Squad
Uk spec 99 rhd dc2 integra
MugenPower
Old Dec 12, 2009 | 09:03 AM
Ls_[eg]hatch's Avatar
mowchowbrowncow
i need to read this thread cause i cant get mine to work either
