garrett turbo on d16
Old Nov 30, 2009 | 09:37 PM
94mightymax's Avatar
Default garrett turbo on d16
i have a built d16z6 bottom end
block guard, vitara pistons, cusom length fjt rods, acl bearings, arp head bolts.
and i picked up a garrett turbo cheap and was woundering if it is to big for my setup? and what would it spool at?
garrett t3/to4s 60 trim (466159-5004)
thanks for your help
Old Dec 1, 2009 | 05:21 AM
dippincrx's Avatar
save the s.o.h.c
60trim garret sounds a little big. might want to go down for quick spool. look around on d-series.org alot of good info
Old Dec 1, 2009 | 06:01 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
what's the A/R size? .48 will have a power band of around 3000-7000 rpms, .63 will be around 4000-8000 and the .82 will be around 5000-9000. these numbers are based on a T57 Garrett turbo which is slightly smaller then the T60.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Dec 1, 2009 | 11:18 AM
it's a .63 a/r
Old Dec 1, 2009 | 03:24 PM
CRAWFORD BUILT
+ it'll spool quicker the shorter your manifold is.
CRAWFORD BUILT
DC Crew Member #23
Old Dec 1, 2009 | 04:30 PM
YARO's Avatar
Smith & Wesson Protected.
Thats a small frame turbo so don't worrie about it beeing to big... DO NOT go with a .48ar t housing cause that'll choke up and create back pressure. Whats the power goals and what purpose is the car used for?
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Dec 1, 2009 | 05:08 PM
dippincrx's Avatar
save the s.o.h.c
doesnt wheel trim come into play? not just the sizing of the housing?
Old Dec 1, 2009 | 05:17 PM
YARO's Avatar
yes but according to that part number is only a certain turbo with optional housings.
