Greddy Oil Filter Block Adapter... TURBO HELP!
Old Nov 18, 2009 | 10:41 AM
2K TEG's Avatar
It's only the beginning..
Default Greddy Oil Filter Block Adapter... TURBO HELP!
Hey all,
i am about a week away from installing my custom turbo kit on my LS b18b.. i got a Garrett T3/T4 60 trim turbo (shipping now!!! ) , i purchased the greddy oil filter block adapter to use for my send/return lines for oil cooling. after looking at it.. it seems to be only for sending the oil and nothing for the return! i was wondering if i can use it for both.. if not i need some other options for a return line... thanks! repz for bumps and advice!
here's the link to the greddy adapter (the greddy website didnt work for me so here are some retailers links) thanks!
Engine: Oil Filter Block Adapter :: NIPPON POWER
00 Integra LS/Turbo - Traded
06 GSX-R 750 - Sold
08 Daytona 675 - My Toy
12 Si Sedan - DD
Old Nov 18, 2009 | 01:22 PM
FrodoGT's Avatar
Found the Vtec switch.
Lol..did you even search google for turbo oil return?
It dumps as short and as direct as you can without burning/melting/kinking it...right back into the oil pan.
TR Old Skool EF Crew #24
Old Nov 18, 2009 | 04:12 PM
2K TEG's Avatar
yeah i did search, i just didnt wanna cut/weld a hole into my oil pan... thats why i wanted to know if the greddy piece will work for send and return..
06 GSX-R 750 - Sold
12 Si Sedan - DD
Old Nov 18, 2009 | 04:15 PM
FrodoGT's Avatar
No, that location on the block only supplies Pressurized oil, and the turbo is a gravity drain only.
And its just a drill bit..and you could JB weld a fitting in if you so chose. But nonetheless it is the only way.
Old Nov 18, 2009 | 04:18 PM
YARO's Avatar
Smith & Wesson Protected.
Do it right and weld a -10an or -12an fitting in you oil pan. like FrodoGT said, you can't can't return to a pressurized spot. It has to gravity return to the pan.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Nov 18, 2009 | 04:21 PM
2K TEG's Avatar
ok... can i use the greddy for atleast the send line then?
reps for yall. thanks
06 GSX-R 750 - Sold
12 Si Sedan - DD
Old Nov 18, 2009 | 04:23 PM
YARO's Avatar
Yea for the feed is fine.
Old Nov 18, 2009 | 04:27 PM
2K TEG's Avatar
any recommendations for the return? im not a huge fan of buying 'universal/generic/ebay' products...
06 GSX-R 750 - Sold
12 Si Sedan - DD
Old Nov 18, 2009 | 04:33 PM
YARO's Avatar
-10an fitting with steel braided hoses
Old Nov 18, 2009 | 04:35 PM
2K TEG's Avatar
aight.. i'll see what i can find.. no performance shops in Gainesville
06 GSX-R 750 - Sold
12 Si Sedan - DD
