02-05 Si Hatch (EP) Wheel Bearing differences?
Old Nov 16, 2009 | 07:18 PM
rotary nation's Avatar
is full of Hondas =/
Default 02-05 Si Hatch (EP) Wheel Bearing differences?
I just bought my EP3 about 2 weeks ago and its got some mileage on it (74k). When I went to go get a set of new tires today the mechanic at firestone let me know (and showed me) that my front driver side bearing has some play in it and probably is going out soon. So I'm shopping for bearings on the web tonight but apparently for 04-05 EP's the bearings are different because all the other bearings I find are compatible for 92-03 civics but the sites all say "Except 04-05 Si". Is there a difference between the bearings or is it just me? I haven't found a site yet that has the "04-05 Si" only bearings so any light on this matter would help greatly. Thanks H/A TR.
Old Nov 17, 2009 | 06:34 PM
SEEKERone's Avatar
Trialed for Treason
just checked honda OEM part numbers and intermix
02-03 EP3 wheel bearings and different from the 04-05 EP3
AND neither are the same as the non-EP3 bearings as per honda's part catalog
Liar, you couldn't cut me deeper with a knife if you tried
Old Nov 18, 2009 | 02:52 AM
rangcrx's Avatar
engine building &best
^ im with him 92-00 are the same the newer civics use a smaller diameter bearings.i know autozone has them for around 50 each..
i love AUTOZONE
Old Nov 18, 2009 | 05:39 AM
integra's Avatar
90% grind 10% sleep
They changed bearing sizes because 04-05 is 5 lug and the bearing is different.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
