uncontrolled idle HELP!!
Old Nov 15, 2009 | 02:58 PM
blazetmf's Avatar
Default uncontrolled idle HELP!!
i have a 94 civic ex. i came across a problem about a week ago. my idle is uncontrolled. itll go up and down even after the car is warmed up. it drives fine and doesnt overheat but once i put it in nuetral there goes the idle going up and down. can anybody tell me what is the problem? thanks
Old Nov 15, 2009 | 03:26 PM
Invader_Zim's Avatar
Typical TR Asshole
im dealing with the same problem at the moment, its either the idle air control valve, or some people recently have told me that it could be the throttle position sensor
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old Nov 15, 2009 | 03:54 PM
YARO's Avatar
Smith & Wesson Protected.
idle air control valve, tps mabye. I had this problem happen to me and it was my intake manifold gasket broken.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Nov 15, 2009 | 03:57 PM
mtber's Avatar
fast idle thermo valve needs to be rebuild probably....
Old Nov 15, 2009 | 04:01 PM
blazetmf's Avatar
thanks guys thats what i was told it was but i just wanted to make sure....is the tps the little sensor that is right next to the idle control valve?
Old Nov 15, 2009 | 04:23 PM
thegoldenchild's Avatar
yes, check for codes so we can further assist you
Old Nov 19, 2009 | 06:20 PM
mogo21's Avatar
first thing i would do is eliminate the idle air control plug up the hole in the TB (JB weld putty)and create a small vacuum leak to control idle as u see fit , thats what i always do my car runs and idles great
Old Nov 19, 2009 | 06:35 PM
SuburbanNoize's Avatar
Cold Ass Honky
^ def do not do that LOL get a new IACV
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Nov 19, 2009 | 06:41 PM
YARO's Avatar
No fucking way. How can you advertise in your sig that you do work and fab and post something like this?? .. is it raining morons in the honda/acura tech section? WTF. Don't do what mogo21 is saying. Listen to SuburbanNoize and the rest of us source the problem and fix/replace faulty parts..
Old Nov 19, 2009 | 06:58 PM
Typical TR Asshole
