No compression 2 cylinders WHY!!
Old Nov 11, 2009 | 06:30 AM
StrictlyBusiness's Avatar
Mr. Stealyogirl
Default No compression 2 cylinders WHY!!
Ok so heres the dealio. Im not gonna get into full detail but heres the jiff. New head, done at Total Performance all new everything. Put it on the car and NO compression in cylinders 2 and 3. Did a leak down and came back to the head. What are the posing problems? Valves not seated or what? What can I do with it on the car etc etc. They said check my valve lash. They said if they are to tight I wont have any compression because its holding the valve open which does make sense. Anyway, so yea suggestions please?
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Nov 11, 2009 | 07:03 AM
Mr. Stealyogirl
As I read more and more, Im leaning towards adjusting valve lash. I just read this and this seems exactly like my problem
No Compression aft reman head install 94 teg RS
And this aswell
http://honda-tech.com/showthread.php?t=1767861
www.jdmmindz.com
Old Nov 11, 2009 | 11:07 AM
mogo21's Avatar
yup sounds like valve lash unless, head wasent built properly
Old Nov 11, 2009 | 12:06 PM
rangcrx's Avatar
engine building &best
yup sounds like you need to redo the valve adjustment
i love AUTOZONE
