Turbo question.....
Old Nov 1, 2009 | 09:23 AM
Civic97's Avatar
Default Turbo question.....
I have a b18b turbo.
My question is.. are the rocker arms supposed to have more play than usual because it is turbo or should they be adjusted to spec???
Thanks
Old Nov 1, 2009 | 10:02 AM
YARO's Avatar
Smith & Wesson Protected.
adjusted to cam spec. If it has stock cams yes stock spec you use.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Nov 1, 2009 | 10:42 AM
Civic97's Avatar
thanks!!
Old Nov 1, 2009 | 11:22 AM
sprjit22's Avatar
Rick James bitch
Stock specs
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Nov 1, 2009 | 05:19 PM
FrodoGT's Avatar
Found the Vtec switch.
The only thing that might be looser than factory spec when doing a turbo build would be the piston to wall clearance, and possibly ring end gap. Cams will be factory spec or whatever spec your cam specifies.
TR Old Skool EF Crew #24
Old Nov 1, 2009 | 06:07 PM
01LatinVizionGSR's Avatar
Definitely factory specs which if i'm not mistaking 0.07 intake and 0.09 exhaust. Always adjust your valve lash clearances to spec when running stock cams and even if you ran aftermarket cams most companies recommend oem specs.
Old Nov 1, 2009 | 06:17 PM
custom240sx's Avatar
DC Crew Member #1
^ those are close to the loose end of factory specs...I do .005 for intake and .007 for exhaust (I think those are the numbers) but anyway you should always put them to the lowest end of spec so they don't need to be adjusted as often.
Old Nov 2, 2009 | 12:28 PM
Civic97's Avatar
Cool thanks!! Alot of good info
Old Nov 2, 2009 | 01:38 PM
FrodoGT's Avatar
Im not sure on the B18A/B but a b16/ is .006 and .007, I believe a b18c1 is like .007 and .008..
