mini me swap question
Old Oct 14, 2009 | 09:08 PM
datunnin08's Avatar
Exclamation mini me swap question
i got a d15b8 bottem end and put a z6 head on it. i only had d15 b7 head studs so i used them. now its leaking oil between the head and block.
What kind of head studs should i have used or should buy to put in it.
lmk dont get on here much but text me some answers please 863-651-5045
Old Oct 14, 2009 | 10:57 PM
Nandosol's Avatar
Garage Slut
Did you use a new headgasket? Use the studs from the correct head
Old Oct 16, 2009 | 02:36 PM
datunnin08's Avatar
i used a head gasket that i put on before but was only on for a few mins. but i shouild use b8 head studs from that block
Old Oct 18, 2009 | 11:21 PM
monsterx10's Avatar
did u tighten to spec??? and get a new gasket i just did mine and used the bolts from my head and used them on my new one they are fine and once u get the new gasket dont just get right on it grandama drive it for about 100miles to let the gasket settle or u could leak also happend good luck hope that helped a lil
