Integra Ac Problem!!!!
Old Sep 28, 2009 | 06:38 PM
integraturbo's Avatar
Default Integra Ac Problem!!!!
trying to get my a/c to work. it does not turn on at all when i turn on the ac. compressor does not click and fan does not turn on, but both fans turn on at operating temperature via coolant temperature switch. hot wired the ac compressor and it clicks on ok. both relays work fine and is getting power. there is enough pressure in the system. all fuses, relays, wires, and connections are fine. help
Old Sep 29, 2009 | 08:12 AM
RoadRacer's Avatar
Turn 7 at Sebring
Did you hot wire it by jumping the pressure switch?
Patrick -
Old Sep 29, 2009 | 10:27 AM
i hot wired it from the battery to the compressor and it turns on perfect and blows cold
Old Sep 29, 2009 | 01:23 PM
rangcrx's Avatar
engine building &best
you may want to check the lil box ontop of the Evap box behind the dash
i love AUTOZONE
Old Sep 30, 2009 | 03:35 PM
is that the thermostat?
