Two things i learned saturday...
Originally posted by "Someone"
Originally posted by 88EFSiR1J1
I have a ? for Track racing such as this my friends and I race in neighborhoods that dont haev houses built yet just curved street and nothing but dirt surounding it ( very good place since the road is new ) and whats the best way to eliminate understeer on a front wheel drive? I have front and rear strut bars do I need to stiffn the front or the back? everything else is setup for this ( like my Brakes )
-rear tibar
-small or no front swaybar
'00 FBP Si
Sebring rule in effect
'00 FBP Si
should I take out the front strut bar for now will that help at all?
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
14.729 @ 94.79
i would leave the tower bar in it still helps structural rigidity and wont give you any more oversteer. just get a rear swaybar at first and then go from there to see what you like.
'00 FBP Si
'00 FBP Si
Guest
Posts: n/a
basically you need to increase your spring rates in the rear or soften them in the front. Sway bars are just a means of increasing your effective spring rates. If you have adjustable shocks setting them on firmer settings are another way of increasing your effective spring rates. You can also play around with tire pressures less pressure in the back will help the back end come around but can cause sudden snap steering if you unload the suspension too quickly (during an avoidance move). Adding more weight to the back of the car also helps as far back as possible or taking weight out of the front.
