is there a diff between a obd0 and obd1 ect sensor
Old Sep 10, 2009 | 08:57 PM
sullivanracing06's Avatar
Default is there a diff between a obd0 and obd1 ect sensor
are the eletronic coolant temp sensor the same sensor? as in dose it still send out the same signal to the ecu or since one is obd0 and the others obd1...
just thinking out loud,
also thinking would a bum ignition switch be messing me up, seeing it starts and runs fine after been sitting then when the car wheel hops and jiggles it loose or a wire loose?
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
