DA w b20b boost problem. HELP!!!! shuts off after i hit boost
Old Sep 10, 2009 | 11:34 AM
sullivanracing06's Avatar
Default DA w b20b boost problem. HELP!!!! shuts off after i hit boost
i have a 91 integra ls that i swapped a b20b and a 18g greddy turbo, cast manifold and outlet on, for fuel mang im running a 10-1 fmu (only untill my emanage harness arrives) and a walbro 255 pump. when ever i hit boost the car gose into limp mode the first time, the second time i hit boost it shut off and will not start again,
the ecu throws 6 n 7 for codes which are the ect and tps, i just installed a brand new dizzy on it, im fucking cluless and am remembering why i stopped owning hondas and switched to nissans. and help would be appreciated!
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Sep 10, 2009 | 12:13 PM
JoKiE crx4294's Avatar
popeye built!
stock map sensor only reads 10 psi. if it sees more than that it will go into limp mode.
Can't spell strength without tren
AAS...It's whats for dinner
Old Sep 10, 2009 | 01:34 PM
96spydergst's Avatar
Default ...
boost solinoid and 3 or 4 bar map sensor...And 10:1fmu...jeez get hondata or some type of chip and take it to the dyno.
I believe in a lively disrespect for most forms of authority.
96 eclipse gst drop top sold
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
Old Sep 10, 2009 | 01:45 PM
NeKe1point0's Avatar
time for a tune !
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Sep 10, 2009 | 03:40 PM
i guess what im asking is, when the ecu goes into limp mode means it has no power?
why dose it not restart after it enters limp mode?
Sullivan Racing LLC
352-665-2496-Tom
Old Sep 10, 2009 | 06:51 PM
mtber's Avatar
1. Remove the fmu
2. Resolve all codes
3. Get the proper engine management, injectors & fuel pump
4. Have the car properly dyno tuned.
Old Sep 10, 2009 | 07:22 PM
SUPAFLY's Avatar
it still shud run in limp mode its a safe zone 4 your motor
TR "Old Skool EF" Member #152NO BOOST!!!!JUST MY FOOT AND THE BOTTLE!!!!!CRX SiR
88 crx dx-wrecked
91 crx si -project 300 whp allmotor-solddd
95 teggy-parting out
91 ex 4 door -sold
97 ek civic dx boosted-400whp
98 teggy gsr-dd
8137704076 b series parts for sale let me kno what you need
Old Sep 10, 2009 | 08:33 PM
im removing the fmu, installing a extra set of 550s and using a emanage and my aem wideband for tuning, this is a temporary fix, just need it till my other harness arrives, just wondering if ne had a input?
i checked voltage at the tps and its not getting 0-5v on any of the 3 prongs
Sullivan Racing LLC
352-665-2496-Tom
Old Sep 10, 2009 | 08:36 PM
mtber's Avatar
1. Do not run the emanage.
2. Use the helms manual to troubleshoot your tps.
Old Sep 10, 2009 | 08:37 PM
emanage dosent work well with hondas? works great with my rb
Sullivan Racing LLC
352-665-2496-Tom
