B16 problems
Old Sep 6, 2009 | 08:08 AM
mikeso's Avatar
Default B16 problems
my B16 is not turning on im not sure what the problems is. the spark plugs are getting no spark so i was wondering if anyone could help me out like come by and check it out or something PM me
Old Sep 6, 2009 | 09:26 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Probably your distributor.
-Winston Churchill
Old Sep 6, 2009 | 01:47 PM
mikeso's Avatar
is there any other problems that it could be because the person that had it before me told me it could have been the main relay but im not sure i just want this car to run before the 19th
Old Sep 6, 2009 | 04:22 PM
wolfenr1984's Avatar
Great White Hope
Check the coil in the distributor, the main relay, then possibly the ignitor. It's almost always the coil. If you have a later model Honda, it just may be the main relay alone.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Sep 6, 2009 | 07:05 PM
TheRichMan's Avatar
isn't actually rich...
Happened to me, it was the coil. Check that for sure
Old Sep 6, 2009 | 09:05 PM
mikeso's Avatar
the car is a CRX if that helps any but i will check the coil when i figure out how...i hear that its most likely the main relay so ill check the coil first and how do i fix it if its the coil
Old Sep 7, 2009 | 10:26 AM
Test with a volt/ohm meter, or an LED style test probe to protect your electronics.
If bad coil, put on one that you know is good. Swapping one wire at a time.
Maybe get a spare from a junk yard and test them both.
Plastic bag the spare, label it and keep it on the shelf...-Bob
Old Sep 7, 2009 | 03:35 PM
mikeso's Avatar
idk what the coil is suppose to look like and im not sure what im doing but i dont ahve any of those tools u want me to use but which would be the more convient and cheapest way to go to fixing the problem
Old Sep 10, 2009 | 10:35 AM
The coil will look like the one that you have on the car now.
Shoot us a pic inside the distributor and we can tell you which part it is.
I test 'em to be sure that I'm not putting on a bad one
or I would use a good coil from a car that runs....
Convenient and cheapest......
If bad coil, put on one that you know is good, either from a buddy's car or from a junkyard. Swapping one wire at a time.-Bob
What part of town are you in?
Old Sep 11, 2009 | 08:43 PM
Default LKQ locations-St Pete
You are in luck. You are close to LKQ u-pull it.
It costs $2 to get in their yard. One yard near downtown, and a better one near the St Pete/Clearwater Airport.
They can print out an interchange list of what distributors will interchange with your car......then you can prowl their yard for a car with a good distributor and/or parts.
The list (worth $2 to me) goes into your tech folder for the car, for future reference.-Bob
