Recommend a shop for a job.
Here's the skinny..
Driving on 275 today I heard an awful noise and looked out my rear mirror as my crank pully flew behind me.
Apparently the previous owner did a dipshit move and overtightened the crank pulley bolt, thus The Crank Pulley Bolt SNAPPED off inside.
it's too far to remove without an extractor (vice grips aint gonna do it..)
I do not have my air tools in Tampa, and don't want to make matters worse by breaking off an Extractor bit inside the crank bolt.
Lmk what you guys think
This sucks.
This sucks.
change the crank,this just happened to HonkeyDong's GSR. Pm him or me i will do the work and he will vouche.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
use a dremel/die grinder to the end of the bolt. The use a impact screw driver with a flat head bit. Then hit with hammer.
727-510-6301
I can probably get the bolt out.
Recently I removed a domestic-threaded crank bolt
that someone had impacted into a Honda, resulting in a
beat up crank pulley that wobbled, a damaged keyway in the crank,
a damaged keyway in the crank pulley, etc. etc,.......
I sure wish that guy had me do the work to start with.
It would have saved him some money to get it done right.
I also do on-site impact wrenching for crank pulleys and
many other things. PM me if you want someone to look at it.
What part of town are you in?-Bob
its going to be VERY VERY hard, that is the highest grade bolt on the whole motor and next to the frame support bolts highest on the car..its going to take alot and i dont even think there is a bit Dremal sells strongEnogh to cut into it..maybe you can tig weld a allen wrench on the bolt and try that
i love AUTOZONE
i love AUTOZONE
Moving You to Honda / Acura tech
TR"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
just get some good drill bits and a extactor kit and your good to go. i would not go through replacing the crank.
