Recommend a shop for a job.
Old Sep 3, 2009 | 06:40 PM
JoKiE crx4294's Avatar
popeye built!
Originally Posted by rangcrx
its going to be VERY VERY hard, that is the highest grade bolt on the whole motor and next to the frame support bolts highest on the car..its going to take alot and i dont even think there is a bit Dremal sells strongEnogh to cut into it..maybe you can tig weld a allen wrench on the bolt and try that
thats what i was thinking.
Can't spell strength without tren
AAS...It's whats for dinner
Old Sep 3, 2009 | 06:42 PM
AllShowNoGo's Avatar
Rang knos his shit
Old Sep 4, 2009 | 04:30 AM
KJ's Avatar
KJ
bored at work
If the bolt broke because it was overtightened then with the head off there is no longer any tension in the bolt and it will come off easy. If the bolt is cross threaded or seized you will be replacing the crank. I used to see this all the time on early h23 motors and could never extract the bolt. If it siezed then you can remove the crank and have a machine shop redrill and tap the block but at that point you might as well replace the crank.
Old Sep 4, 2009 | 06:08 AM
PooN_Lude's Avatar
The head is snapped off, so tension is not going to be a problem.
i haven't purchased a new drill/decent extractor kit yet, so i have yet to see if its cross threaded. I hope not.
Old Sep 4, 2009 | 01:14 PM
rangcrx's Avatar
engine building &best
i would try craftsmen might be your best bet..good luck with it and keep updated i know i would like to know..and find a nice heat gun to warm it up to,DONT USE a torch you will malt your oilpump seal
i love AUTOZONE
Old Sep 4, 2009 | 01:20 PM
PooN_Lude's Avatar
Senor Honda came and gave it a try today.
No luck, the extractor bits may have been too soft.
I'm going to try and buy some heavy duty extractor bit and give that a shot.
Old Sep 4, 2009 | 01:30 PM
  #17 (permalink)
rangcrx's Avatar
you will need some super cobalt Extractor and bit to get thru that bolt,to me it will cost you less to try and weld
i love AUTOZONE
Old Sep 6, 2009 | 07:30 AM
  #18 (permalink)
KJ's Avatar
KJ
bored at work
If it is giving you that much trouble start looking for a new crank.
Old Sep 6, 2009 | 07:38 AM
  #19 (permalink)
WhiteNgold's Avatar
is underwater
Default crank
+123132241234 on the welding deal.... id personally weld a 1/2 inch short extension to it so u can get a breaker bar on it or use an impact
Old Sep 6, 2009 | 10:45 AM
  #20 (permalink)
rangcrx's Avatar
^dont know if that would fit,thats why i would say allenWrench that way you can just turn it yourself...otherwise like Kj said New crank if you mess it up to much trying to get the broke one out
i love AUTOZONE
