2002 civic ex motor
has anyone gotten a chance to see a 2002 civic ex motor? its my understanding that these engines are mounted like all other d-series rather than inversely like the k-series. and if thats true then these motors could bolt into older civics right?
thanks chet.
thanks chet.
to answer your question....yes and no. the 2001+ civic sohc motors are d series sharing similar configuation size etc. BUT engine mounts entirely different including front mounting of the alternator between power steering pump and a/c compressor....the is no provision for a distributor and the engine sensors operate in a completely different manor. the added displacement comes from slightly longer stroke but the crank is a new design...different size main bearings. i believe the bell housing is the same so earlier trans could be bolted on but 01+ trannies are now cable shifted---not rod shifted as they have been. could it be done...yes---would it be worth the time money and effort....no way.
Liar, you couldn't cut me deeper with a knife if you tried
Originally posted by "Someone"
Originally posted by Brandon Swan
who cares they are little pussy engines either way
true...true...
I'm not running in circles
I'm just cutting corners
