crx trouble
did you check to see if your head was warped or any cracks in the head?
you got spooks in that motor.....
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
bro im not sure but i got the head re surfaced and check it was good ....do you kno anyone with a dx dizzy or a si dizzy ?? i have everything 4 the mpfi swap but the dizzy im try the dizzy if it dnt work i will prolly b selling or trading it for a eg if i can or a gst
TR "Old Skool EF" Member #152NO BOOST!!!!JUST MY FOOT AND THE BOTTLE!!!!!
CRX SiR
88 crx dx-wrecked
91 crx si -project 300 whp allmotor-solddd
95 teggy-parting out
91 ex 4 door -sold
97 ek civic dx boosted-400whp
98 teggy gsr-dd
8137704076 b series parts for sale let me kno what you need
CRX SiR
88 crx dx-wrecked
91 ex 4 door -sold
98 teggy gsr-dd
if was getting hot when you were still, most likely your cooling fan wasnt coming on
You need to fix these things if you want to have a running motor for a while after you fix it.
Have you checked compression after changing the hg? If you still get white smoke, then obv youre still burning water
my cooling fan is coming on ...naw havent did a comp. check but if it is comp. y when i turn the key and push the gas pedal the car will rev over 3 rpms no problem?? andif the car is cool it will start and try 2 keep a constant idle till it starts 2 heat then it jus almost dies but is still running
CRX SiR
88 crx dx-wrecked
91 ex 4 door -sold
98 teggy gsr-dd
CRX SiR
88 crx dx-wrecked
91 ex 4 door -sold
98 teggy gsr-dd
are you low on coolant? if its white then its coolant, you blew your hg
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
i changed my headgasket .....i think its the dizzy im jus get rid of this dpfi bullshit and go with a obd1 swap harness if i can run a obd1 dizzy off a pg7 and if it bolts to my head i think i will b good to go what you guys think do you think it will work ??
obd1 dizzy on d15b2 head ??
obd1 dizzy off a pg7 computer ?? (temp.)
CRX SiR
88 crx dx-wrecked
91 ex 4 door -sold
98 teggy gsr-dd
CRX SiR
88 crx dx-wrecked
91 ex 4 door -sold
98 teggy gsr-dd
Im thinking your problem is way more than the dizzy. You need a compression check to further diagnose this problem. How many miles are on this motor? Single cam swaps are cheap or might be time for DOHC swap?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
215k but it still pulls strong .....i lik the under dog motor single cam
CRX SiR
88 crx dx-wrecked
91 ex 4 door -sold
98 teggy gsr-dd
CRX SiR
88 crx dx-wrecked
91 ex 4 door -sold
98 teggy gsr-dd
read the check engine codes and i can help you trouble shoot it from there
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Non-VTEC:$20-up
VTEC:$40-up
