Door Check on an EF
Old Aug 21, 2009 | 09:54 AM
Steve-O's Avatar
Fiat Specialist
Default Door Check on an EF
How do you replace the door check on an EF?
(Driver side prefered but both would be nice)
Pics would help greatly.
Thanks in advance
1990 Honda Civic DX Hatchback - SOLD
2006 Scion tC - Traded
2013 Fiat 500 Abarth - Current DD
Old Aug 21, 2009 | 10:03 AM
custom240sx's Avatar
DC Crew Member #1
I welded mine back on if your saying that yours rusted and broke off.
Old Aug 21, 2009 | 10:09 AM
Steve-O's Avatar
Fiat Specialist
Nah just makes noise and snaps and makes the car feel even more shitty than it is xD
Passenger side its fine but would like to know how to replace that side also for when the time comes.
Old Aug 21, 2009 | 10:18 AM
DC Crew Member #1
If it is popping it is most likely broke off inside the door...thats how mine started. You have to take off the door panel...there are quite a few screws holding it on...roll the window all the way up and once the panel and speaker are completely off you will be able to get to the hinge inside the door.
Old Aug 21, 2009 | 10:24 AM
Steve-O's Avatar
Fiat Specialist
so i dont have to worry about anything under the dash or behind the fender or whereever?
Old Aug 21, 2009 | 10:28 AM
DC Crew Member #1
Shouldn't need to...usually that clunking sound is the spring thing inside the door...when I took my door panel off there were like 4 pieces of that arm at the bottom lol
Old Aug 21, 2009 | 10:36 AM
Steve-O's Avatar
Fiat Specialist
i dont hear any rattling in the door though?
Old Aug 21, 2009 | 10:40 AM
DC Crew Member #1
I didn't either...just take off the panel and inspect everything...it can't hurt any plus you will have an idea of if it is inside or outside of the door that is messed up.
Old Aug 21, 2009 | 10:49 AM
Steve-O's Avatar
Fiat Specialist
Cool deal thanks a bunch! Rep'd
Old Aug 21, 2009 | 10:54 AM
DC Crew Member #1
Mine was the outside part mostly...the inside sliding mechanism was intact so we just broke the rest off from the outside panel and welded it on...the outside part doesn't move so it can be welded.
