what do i need to swap a f22 in my eg
h-series all day.. dont let anybody down u on what swap u wanna do if u need help doin the f swap lmk. i did my h22 myself (neal did wire harness and chipped my ecu) but as far as dropping the motor in is pretty easy with a lil modifications to the frame and mount on tranny side due to big tranny. @ accordnly jdm - i see u said the f22 is boost friendly do u know anything about the h22 being boost friendly?? i wanna build my h22 and goo boost or spray but i heard spray does some damage if u use it alot.
^ill explain later, im at work, H22s are fine on boost and spray as long as you have a knock free never lean tune.
Ringlands give way at high heat even more with detonation. But ive seen a stock H22 do as much as 390whp
Sprayed a 150 shot wet on my room mates H22 for years. no issues
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
TR H2B crew #2
Slap yourself.
And to all the other faggots going J. You know you have to have a hood to drive on the streets right? There are some people gettin busted for cutting the hole to fit the IM too. It looks like shit and ruins the car. If it actually fit that would be different.
I slapped myself, and enjoyed it. thanks
The j30/32s dont stick out too bad.
YouTube - fukenricen.ca 3.2CL type s in a civic 6cyl civic
Id still rock it.
Id still rock it.
Drama has spoken!
TR H2B crew #2
TR H2B crew #2
Originally Posted by Nandosol
If money is no issue, do some research before you buy something. Go J series . Mounts are available and you got lots of torque.
whoa whoa im out, cock ridin aint my forte
TR H2B crew #2
TR H2B crew #2
