cluster started burning and melting.. look
Old Aug 13, 2009 | 07:55 AM
FarFromStockC70's Avatar
I-Trade!
Default cluster started burning and melting.. look
cluster started buring help - Generation 2 Integra Club™ Forum
Originally Posted by omgwtfbbq!
Protip: set your rev limiter BELOW engine speeds that break things.
Old Aug 13, 2009 | 04:08 PM
Nandosol's Avatar
Garage Slut
you have a short in the cluster itself?
get a new cluster
if it does it again you might be running too much voltage to it
check your fuses(got a multimeter?)
you could also have a short in your wiring
Old Aug 13, 2009 | 04:16 PM
I-Trade!
get a new cluster
how could i be running to much voltage to it.. if the same battery has been in the car.. sence i got it? and ill check the fuses
and no wires are melted? sooooooo a short doesnt sound right.. i really dont want to spend money on another cluster if its gunna do it agian.. then im out even more money i dont have...
Old Aug 13, 2009 | 05:07 PM
thegoldenchild's Avatar
the back of the cluster might be touching a ground
Old Aug 13, 2009 | 05:09 PM
I-Trade!
it was the ground around the cluster that burned? so ground to ground wouldnt be the problem..
