jumper harness??
Old Aug 9, 2009 | 06:42 PM
honda_acura_dude's Avatar
Default jumper harness??
ok i neeed to make my own ecu jumper harness for obd0 to obd1...now it is a 90 civic dx...its dpfi...and i have bought a conver. harness so i can run my b16a in it...now my ? is every pinout i c is for mpfi...so is it the same to make my jumper off one of dem since i have the engine harness to mpfi or is it a differnet setup? thanks
Old Aug 9, 2009 | 06:47 PM
josh352727's Avatar
Its been a while since I did mine, but I think you just have to run 2 extra wires from ecu to the other injectors.
edit
Or find where the 2 other injector wires come out of the engine harness plug and make sure you get them to the proper pinout on ecu.
Old Aug 9, 2009 | 06:51 PM
ok then i juss need a good pinout that somebody knows is good..thanks man
Old Aug 9, 2009 | 06:53 PM
josh352727's Avatar
Yeah, I had like 5 different pinouts that I used for refrence just to be sure.
Old Aug 9, 2009 | 07:13 PM
any good sites with conv. pinouts? thanks
Old Aug 10, 2009 | 07:03 PM
2qk4u's Avatar
MPFI Swap
this might help
Old Aug 10, 2009 | 08:45 PM
bump..need a obd0 to obd1 ecu pin out...tryin to find one that seems right...
