Tranny wont go into Motor
Old Aug 8, 2009 | 05:51 PM
FarFromStockC70's Avatar
I-Trade!
yes i am doing this with the motor still in the car...
and where can i get an alignment tool? or else what size socket? 19mm or 22?
ok thanks for the tips.. repped
Originally Posted by omgwtfbbq!
Protip: set your rev limiter BELOW engine speeds that break things.
Old Aug 8, 2009 | 06:54 PM
Santos's Avatar
had the same issue when i swapped engines, only difference is i had the engine and trans out. i just double checked everything, and just wiggled it till it slid in.
good luck and also check out g2ic.com
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
Old Aug 8, 2009 | 07:20 PM
Nycist's Avatar
NY Till I Die....
i also find it easier if someone turns the crank as i tell them to using the bolt on the crank pulley.....especially with a honda.
Originally Posted by Lime_Green_Hatch
$350,000 in 2 years... and all they had to show for it was some shitty hondas, lol.
R.I.P. Steven Daniel Berry a.k.a. Bush
Old Aug 8, 2009 | 07:33 PM
I-Trade!
yea i have been doing that... but the tranny just isnt level enough... im gunna fck wit it tomorrow.. but i need to get it done.. Prego gf has doc appt monday
Old Aug 8, 2009 | 08:33 PM
Thatguysstuff's Avatar
Hey its that guy!!
Ah... you kinda have to get under it and lift from the back.. a 2 person job sometimes..
did you aline the clutch??
Old Aug 8, 2009 | 09:18 PM
zhillz's Avatar
Porno Music Producer
if everything is aligned including the clutch then you just need to stop being a little fucking bitch and push it in.
Old Aug 8, 2009 | 09:40 PM
  #17 (permalink)
There is a letter prefix or suffix on Honda trannys
which determines what will fit a certain engine.
As an example......
If an "E" tranny mated up with your engine, you will
need another "E" tranny to go back in.
It doesn't matter if you pulled an "F" tranny from an
engine that is identical to your engine..........
It doesn't matter if you pulled the "F" tranny from
a car that was identical to your car.............
that "F" won't fit where the "E" was, no matter
what you do.......by any means I have ever tried.
So....check to be sure the stickers/prefixes/suffixes
are the same on both trannys.-Bob
Old Aug 8, 2009 | 11:18 PM
  #18 (permalink)
4DRintegraT's Avatar
man if i lived n bradenton i'd come help u out, somebody close go help him sometimes thats what it takes 2 people! lol
Rep is Returned
Acura
Old Aug 8, 2009 | 11:19 PM
  #19 (permalink)
BoostedRacerDad's Avatar
Pops
Pmed
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Aug 9, 2009 | 04:40 AM
  #20 (permalink)
I-Trade!
thanks guys... i dunno.. the guy i bought the tranny from said it was an ls tranny ...soo he said it was the same as mine... it looks the same.. the only thing is i can tell you what tranny it is because the sticker is missing on the tranny so ill never know what tranny it is...
