civic a/c freon
Old Jul 23, 2009 | 06:44 AM
97civicproject's Avatar
Default civic a/c freon
i wanna put freeon in my eg but which line do i put it in...the one with the red cap or blue cap? lmk asap thanks
EJ Crew Member #20
Old Jul 23, 2009 | 11:04 AM
97clean's Avatar
Has a slow car
the low side pressure port, it may have an l on it, there different sizes though so which ever the hose fits on
Old Jul 23, 2009 | 03:57 PM
rangcrx's Avatar
engine building &best
you can only put it in one it will not fit on the high side..your info says a 93 you have converted the sstem to r134a right?
i love AUTOZONE
Old Jul 23, 2009 | 04:24 PM
i just bought the car but i guess its r134a
EJ Crew Member #20
Old Jul 23, 2009 | 04:56 PM
rangcrx's Avatar
92/93's are R12 make sure its been converted and cleaned out other wise as soon as you put the r134 in the compressor will lock up
i love AUTOZONE
Old Jul 23, 2009 | 05:03 PM
so i need to empty out the system just to be sure n then put r134a?
EJ Crew Member #20
Old Jul 24, 2009 | 04:20 AM
dippincrx's Avatar
save the s.o.h.c
yes have it flushed out. replace the oil in the compressor. replace drier. the low side hose will be the larger of the two going to the compressor
Old Jul 24, 2009 | 06:59 AM
ok it does have an L and its the blue cap so i guess thats where is goes in after i flush out the system
EJ Crew Member #20
Old Jul 24, 2009 | 07:07 AM
rangcrx's Avatar
After u empty it take out the evap under the dash check the expansion valve if it says r134 on the gold top ur good but if it says r12 u need to change it
i love AUTOZONE
Old Jul 24, 2009 | 08:28 AM
ok but do i need to replace oil in compressor and drier too? or just the expansion valve?
EJ Crew Member #20
