Starter Wiring Question
Greetings Honda owners. I have a simple question but out of frustration of google i didnt find what I was looking for. and my common sense isnt on point for lack of a better term. So my question is how do you wire a simple starter switch when the previous owner of your car that you just bought the car from fucked up the original way the car starts. The car is a 89 CRX HF. From what I can see I can flip this switch to make the starter crank over. But now it wont work. Here are a few pics. Anyone with good info please help. Thanks
TR "Old Skool EF" Member #150
2nd pick, connect the hot wire (yellow) to the starter.
Blue wire, Ground anywhere.
I cant see the key configuration, but normally put the key on the ON position then:
Flip switch untill the car starts and flip switch off.
That is the WRONG switch btw, and you should wire the stock pins into the ignition.
