fluctuating idle
Old Feb 18, 2002 | 10:49 AM
advan7's Avatar
Crazy Go Nuts!
besides the IACV what could be the other causes of my motor annoyingly fluctuating between 900-1500 rpms ive got an ITR manifold on a b17a and an overbored b16a throttle body. allthe vacuum lines look to be hooked up right just wondering what else could be causing it.
I use a buck to wipe my @ss, 'cause see, my sh!t is on the money.
Old Feb 18, 2002 | 11:04 AM
Joe's Avatar
Joe
Sodalime is good.
Manifold isnt quite tight...
This happened b4... just double check ALL bolts/nuts are tight.
Any leak will cause your symptoms... Good luck...
Joe
Originally Posted by President Abraham Lincoln
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Socialized Medicine?
Originally Posted by a former president of the US
One of the traditional methods of imposing statism or socialism on a people has been by way of medicine. It's very easy to disguise a medical program as a humanitarian project.
Old Feb 18, 2002 | 06:07 PM
Bill's Avatar
Livin' in Seattle
Originally posted by "Someone"
Originally posted by Mr Self Destruct
fast idle thermo valves die all the time. Remove the intake and place your thumb over the hole in the bottom of the TB. If the idle clears up theres your problem
bleh let the car come up to normal operating temp leave it running remove the cover on the FITV (two screws) and place your thumb over the hole. If theres suction youve found the culprit.
Old Feb 18, 2002 | 06:09 PM
Bill's Avatar
Livin' in Seattle
Easy way to diagnose vacuum leak is with a can of butane or vacuum gauge. With the butane just release it around the vacuum lines and gasket areas if idle kicks up youve found your leak source. With the vacuum gauge itll fluctuate and depending on how rapid/slow they are and the amount that they fluctuate with respect to a set time you can determine the source.
Old Feb 18, 2002 | 08:27 PM
88EFSiR1J1's Avatar
mabye the throttle position sensor if its not a vacum leak.
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
Old Feb 18, 2002 | 08:58 PM
advan7's Avatar
Crazy Go Nuts!
thanks guys! ill be sure to check all of the above in the morning this idle thing is driving me insane!
teg2gen
Mar 8, 2001 03:36 PM
