Johnson's High Compression H22a build thread ::in progress:: ProvenPowerTampa.com
stage 3 cams there built for 500 hp form what the wesbite says. ? am i wrong. what have you heard about the skunk2 im. i hear its the best out right now for an all motor setup. lmk bro.
I would expect 235-240 depending on how good those cams are. An all out race engine w/ custom everything will make between 290-340. The skunk IM is designed around a mild built engine. The plenum size is on the small side. You have a nice street setup. You will make enough power to move that EG with easy. Like I said dont get stuck on a number.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
