It is ALIVE but now i need to fix this!!!
Open your fuse box under the hood and start looking at the fuses. There are some large fuses in there and one is the battery fuse.
Look and see if the fuse is blown....If the terminal is in two pieces it is blown if not it's good.
Start with fuses and see what you find.
lmao...I have a jumper wire where the fuse should be. Blew mine in sort of the same way...my terminals just accidentally touched.
A few things can make the idle like that...the TPS, IACV, and vac leaks.
. So i just get a new one and pull this one out and then it should be able to go right?
