HELP!!!! 94 boosted ls teg
Old May 15, 2009 | 03:58 AM
Tlassiter's Avatar
Default HELP!!!! 94 boosted ls teg
Ok i had a 94 ls integra with an ebay turbo kit on it. I bought it like that and everything. i took the turbo kit off last night and put stock injectors, intake, and headers on it. When i went to turn the car over it reved to about 2000 rpm and bogged down and shut off. Messed with the timing and stuff but still did the same thing. Im starting to think its the ECU but the only thing is the car wasnt tuned when the kit was put on so idk what else it could be. Im thinkin its still the ECU or maybe a vacum line/ hose or something. ANY ADVICE PLEASE HELP!!! Also whenever i tried to give it gas it wouldnt go past 2200 rpm and if i gave it anymore gas it would again bog n shut off
Old May 15, 2009 | 04:48 AM
jdmek2000's Avatar
have you tried to clean your idle air control valve?
Old May 15, 2009 | 06:34 AM
Tlassiter's Avatar
everytime we sprayed cleaner into the throttle place it ran but when we stopped it bogged back down n shut off. Could it have anything to do with the timing?
Old May 15, 2009 | 09:17 AM
Tlassiter's Avatar
bump. need help please
Old May 15, 2009 | 03:17 PM
sullivanracing06's Avatar
timing on the dist, turn mess with the idle on the t body, did the car run w the turbo kit on it? dose the car have a afc or ne type of fuel mang on it
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old May 15, 2009 | 04:55 PM
sprjit22's Avatar
Rick James bitch
If you dont figure it out I can take a look at it for you. Number in sig
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old May 15, 2009 | 06:07 PM
jcarp613's Avatar
There are a few things it could be. First of all, did it run good prior to pulling the turbo kit off?
Make sure your injectors all work good. Is it missing while it idles? WAIT! You swapped the injectors? The ecu was probably set for the injectors that were in it. Most likely 450s? Borrow a stock ECU from a friend. Start with the ECU, then Injectors. If you can't locate either... Swap the injectors that were in it back in. It will run rich as hell. You need a stock ECU. Keep us posted...
1990 Acura integra Part out! DA. Doors, Catback, Windshield, Wing, Etc...
https://www.tamparacing.com/forums/h...ml#post8243584
D15B2, 5spd Cable Tranny, Dizzy, A/C Parts, Starter, Axles, Tons of D Parts
https://www.tamparacing.com/forums/h...s-d-parts.html
Old May 15, 2009 | 06:35 PM
sprjit22's Avatar
Rick James bitch
I have an ls auto obd1 ecu we can test also. The problem could be many diff things.
T & C Racing
FT Crew Mascot lol
Old May 15, 2009 | 09:03 PM
ThaiRacer's Avatar
i love girls
look i told him its timing car has no tune stock injectors. no fuel management
Like us on facebook
Old May 15, 2009 | 09:52 PM
thegoldenchild's Avatar
^^^^^ we know ur the man but he wants to check diff opinions.
