beating a gsr
im puting the ls motor in my 93 hb what would i need to keep up or smoke the gsr integras and i dont want to use nos im going for all motor like cams etc... thanks
charlie hall
charlie hall
VTEC head to start....then a variety of different mod combos....supercharger or turbo is a sure bet. But Im no expert.....Ask Mr. Self Destruct.....hell know the best combo.
thanks i got the i/t/h what would be the cheapst cams i just want some thing simple im a little low on cash now are the crans any good there like 350 or so any cheaper ones out there
charlie hall
charlie hall
I may be wrong but why not Just Get new intake system New cam shaft the longer the lobes the more air can get in Correct? Then Super Charge it? I dont to much know about these Bolt ons I hear so much about perhaps someoen could explain it to me. I Hear that 3 doors and HBS are faster because they weigh less?
Depending on how much highway driving and your budget you might consider getting a a b16a or gsr tranny. That should help your acceleration quite a bit. As far as the cams I think that crower and crane makes them as well as gude and jg but I cant recommend the jg or gude because of thier reground nature AND NOW I HAVE HEARD BAD THINGS ABOUT THE CROWER ONES BREAKING. You still should be able to take gsrs with a stock ls/hb set up. A guy around here runs a 94 si with an ls milled head(a lot shaved) ported polished and cams and he runs mid to high 13s I think He is running a b16a tranny but Im not sure. My sohc 93 si with i/e ran a 15.4 On street tires you will be faster than gsrs dont worry
dont get crane theyre crap.
dont worry about cams yet put in the motor and be happy with it.Why do you want to beat 15-sec. GSRs? aim a bit higher.
if you decide to build youre motor wait till you have the cash for a VTEC head then id do ITR/CTR cams or some JUN/Toda if you have the money. Dont build it half-assed with reground redneck cams.
Good luck w/ youre project.
'00 FBP Si
Sebring rule in effect
'00 FBP Si
LSVTEC. End of story. I have a hatch and yes it is slightly lighter if you get a b16 head/pistons you will spank the gsr(depending on mods of course) with time to light up a smoke. The torque increase is what will do it right off the line. Dont recommend crane cams. If you want to spend that $350 get a head. If you want to go another route get a ctr or itr intake cam or int&ex cams. Then get some cam gears. That will give you a jump but not nearly as much as an lsvtec. The head is the most bang for the buck but next I would have to say is the cams & gears & dyno tune by destruct.
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
