street tune VS dyno tune
Old May 5, 2009 | 05:42 AM
Alpha's Avatar
OP, You know there is more than one or even two dynos in Tampa right?
Both have their pros/cons. Imo both should be done. But. If a car isn't safe at higher speeds on the road than dyno tune is going to be the only way. And a lot of the Hondas I see are not safe at higher speeds regardless what the owners think/say. On the dyno you're going to have more control of everything. Get your timing curve, find mbt, etc. I could go on and on but in the end it's going to benefit you all to get both a dyno and street tune
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old May 5, 2009 | 05:51 AM
sprjit22's Avatar
Rick James bitch
You have had 2 tuners chime in now their is only 2 (main tuners) that I know of left.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old May 5, 2009 | 06:00 AM
Borilove24's Avatar
dyno> street tune .... my was ecu was chipped and street tune was done by an indivuadal no names this is not about that.... anywho i decided to see jap and and get a dyno tune i have a stock jdm gsr with a hytech replica header first pass car made like 155 whp and like 119 tq after the dyno session was done motor put out 176whp and 134 now you tell me why wouldnt you wait?
Old May 5, 2009 | 03:36 PM
na200whp's Avatar
Powered by BOOST
Depending on your setup you need both. If its mild (bolt-ons) your A/F will be close w/ and good base map. If its more than that (cams, pistons, injectors) you need to street tune and dyno tune. The street tune will give you more in the long run.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old May 5, 2009 | 03:39 PM
FrodoGT's Avatar
Found the Vtec switch.
I would always want both. A dyno tune, unless done on a load dyno will only be able to accurately tune WOT pulls. A street tune get everything in the middle much better and makes sure that the car will run in street conditions. I would always tune my AFRs on the street first then move in to the dyno and go for power with ignition timing and small afr corrections.
Making a car run just like stock is a longer process than just a couple hours on a dyno.
TR Old Skool EF Crew #24
Old May 5, 2009 | 07:53 PM
60-1EK's Avatar
Engineer at the source
As Alpha says, if the car is unsafe or the owner is a dousche....stick that crap on the dyno. If the car is solid and you want real world loads / conditions, put it on the street to start and get it close. Then fine tune on the dyno with IG and cam gears. If you own a dyno dynamics dyno, or something with a brake that you can set the loads (and know how) then put it on the dyno. Touch up things at the track afterwards. Go thru logs and touch up, etc.
But what do I know, my car only went 152 and I haven't had it on a dyno in forever.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old May 5, 2009 | 09:04 PM
  #17 (permalink)
vonrobins's Avatar
love hondas ftw
nnooo where are all the tuners going
._________________________
Old May 5, 2009 | 09:07 PM
  #18 (permalink)
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
They're dying from the swine flu.
-Winston Churchill
Old May 5, 2009 | 09:15 PM
  #19 (permalink)
vonrobins's Avatar
love hondas ftw
damn rosie o donnel and the swine flu
